- Joined
- 6 Aug 2019
- Messages
- 56
- Reaction score
- 1
- Country
I have just dismantled my old oil boiler (22 yrs old) and electrics that go along with it. A new one will be installed later in the year, and moved to a different location due to building works.
In doing so, there are a couple of components in the electrics that I have no idea what they are for.
The system is gravity hot water, plus pump for central heating.
There is one room thermostat, and a thermostat on the hot water tank, which is connected to a single motorised valve to control the hot water.
The timer is a Randall/Danfoss 103. All very simple.
There are two other components that I have no idea what they do:
1. Next to the timer there is what looks like a room thermostat, but it has the face plate blanked off so you cant change it. Inside, you can see it does a have wheel you can turn with different temperatures written on it.
2. There is a box (very old), with a solenoid in it.
I had assumed that both of these were disconnected and were just relics from an old iteration of the system - but they are in fact all connected in..... any idea what they are for?
Many thanks
Many thanks
