Hello again, having yet another dilemma with my vauxhall Astra. (Deisel 1.7 dti estate)
I posted here in this forum about a week ago, I had a problem with oil in the tank...
have A new problem now!
So... took key out of ignition as one does to pop into a shop, when I returned to start her back up, key turned without key gripping onto any notches, just went around. Wouldn't start...
The ignition was gone.
I called a friend and because was in a rush to get going, black boxed it and that didn't work, then tried hot wiring it.. It started for about 3 seconds then cuts out??
Guessing that it's an immobiliser making it cut out..? Is the immobiliser conected to the deisel pump?
Is there anyway to by pass it? I don't have the funds to replace the whole ignition and it's parked in a place where it has to be moved ASAP. .
Thanks.
Thanks.
