Ignition light staying on
25 May 2008
Northamptonshire
I have a vauxhall viva and with the key out of the ignition the red ignition light stays on. When I turn the key the red light goes out and the green one comes on. Has any one got the answer I have tried checking the earth connection.
Usually when the ignition light stays on it's a problem with the alternator
Diodes in alternator they are available seperately but may be nearly same cost as cheap reconditioned unit
Actually, if you read the OP it says that the ignition light stays on with the key out of the ignition.
If the light stays on with the engine running, it indicates a fault in the charging system (alternator, drive belt, connections).
If the light stays on with the key removed, it suggests that the ignition switch is faulty (not turning off). This suggests that the switch may need replacing.
With the old Dynamo setup, the points in the Lucas regulator box fuse closed, which causes the ignition light to stay on when the key is removed.
A diode gone in an alternator will make the light glow brighter when the engine is revved.
