The above machine (which I think may be a re-badged Whirlpool model) will not start the dishwashing cycle. When the power on button is pressed, one LED, the 65C, lights up, but the select/cancel button has no effect, i.e. that should cycle through the different wash options.
Does anyone know what the possible problem is and the solution? It's like the logic circuit needs a 're-boot'. Tried switching the mains power off at the wall and opening and closing door a few times (in case the door latch was not giving the 'door closed, safe to commence' microswitch command).
Is there a procedure such as:- 'hold down power button for thirty seconds, whilst doing X' to re-set it ?
Is the service manual available ? (Is there an equivalent USA model? as often manufacturers over there seem to be obliged to publish the service information.)
