I have an Ikea mixer tap (photo below) that leaks at its base when the cold water is turned on. The leak is between the sink and the base of the tap. (Can just see it on the photo).
I am presuming new O-ring(s) will sort the problem out. Before I start, what is the sequence to gain access to the O-rings? And what size O-rings am I likely to need?
Thanks,
Thanks,
