Evening all, I'm looking for a bit of advice with a faulty dishwasher.
I have an integrated Ikea Whirlpool DHWB10 which has started displaying the "6 flashes" fault. That is, you try to run a programme, you hear the pump run for 10-15 seconds or so, and then the machine beeps continuously until you open the door and it displays 6 flashes.
6 flashes is a "no incoming water" error, and this is what I've trouble-shooted so far:
1) Checked flow from the mains - all OK
2) Checked inlet and outlet hoses aren't blocked or kinked
3) Replaced inlet valve - no change
4) Disconnected water flow reed switch, and checked that it operates when a magnet is passed close to it - it does, all OK.
I've now run out of ideas for what to check next. Does anyone have any ideas before I call in a professional?
Thanks in advance.
Thanks in advance.
