Hello,
My bathroom has been stripped back to bare brick and before the plasterer comes to render I'd like to run the cable needed to power the illuminated mirror.
I have one of these on order...
http://www.onlinelighting.co.uk/sho.../astro-imola-illuminated-bathroom-492942.html
The unit is IP44 Rated, Double Insulated and has it's own switch.
So I have three and a half questions:
1. Since no earth is required should I use flex or can I use the same T+E as the lighting circuit? I'm thinking T+E would be better incase the fitting is replaced with one that needs an earth. If so what's the best way to terminate the earth?
2. The cable will be pinned to the wall using clips and covered with steel galvanised capping before being cemented over. Is that ok?
3. Will this feed directly from the current ceiling light or will it need to be a fused spur?
Part P aside, I'm just ordering the components and laying cable runs, but I like to understand what the electrician is doing in advance
Many Thanks
Many Thanks
