Hi
I'm planning to install an immersion boost switch like this.
The existing standard 20A DP switch is stupidly positioned (behind the cylinder) so I'm planning to put the boost switch in a more sensible place, but leave the existing switch and immersion supply flex in place (to keep the cables neat).
Question is, can I run 1.5mm 3-core & earth from the existing DP switch to the boost switch, with the switched live back to the original immersion heater live, and the neutral load/supply at the boost switch looped together?
Or do I need two separate twin core & earth cable runs - one in and one back?
(Immersion heater is on its own circuit - new CU a couple of years ago.)
Cheers
Cheers
