Apologies in advance if I'm asking daft questions - I appreciate that some of what I'm trying to achieve might be mutually incompatible, but I'm trying to suss out the best system possible.
We are in the process of refurbishing a small cottage to move into. The space heating will all be electric, so this query is only re. water heating. We had been thinking of going down the route of an unvented system (and of course getting it professionally installed by someone who's G3 compliant). However my understanding is now that our water pressure is not up to providing adequate performance unvented... so, I'm looking at vented systems, and as a result thinking that it might be feasible to DIY it.
As far as the installation goes, there will be a kitchen sink, bath, bathroom basin and mixer shower, all installed on the ground floor. The airing cupboard space is also located on the ground floor.
I understand that a typical vented system would have a cold water tank in the loft. That would be pretty tricky in the cottage. So, I'm wondering whether I could get away with installing a small cold water tank immediately above the cylinder in the airing cupboard - my understanding is that a setup like that would completely clobber the chance of getting decent hot water pressure from the cylinder, as that comes from the height that the cold supply is above. But if it's otherwise compatible I think we would be happy with resolving that by using a pump. (All the cold taps can be supplied off the mains anyway - I wouldn't be looking to supply them off the cold tank.)
So, my question is - would that setup work? I think what I'm describing might be roughly equivalent to a fortic / combination cylinder, but from my reading I can't quite work out whether they are compatible with pumps either. If they are - would that be a better way of going than my Heath-Robinson version?!
Is there anything else I need to be watching out for? What sort of size of cold water tank do I need to stop it running out if I can pump hot water? Is that any different if I can work out a way of getting the tank into the loft? (The pipe runs are a major issue, with lots of immovable timbers causing problems.)
Another thing - if possible I'd like to specify a cylinder that is 'solar ready' - we probably won't be able to put in solar HW at the moment, but I'd like to at some point relatively soon, and don't want to have to replace the tank at that stage if I can avoid it. Does anyone have any advice on specifying a cylinder that has preferably 2 immersion heaters for use now, good insulation, and a solar coil ready for a later upgrade?
Thanks in advance,
Jamse
Thanks in advance,
Jamse
