Immersion heater advice
15 Jul 2008
Hampshire
I'm in the situation unlike the original post holder above that my hot water is supplied by a Gas boiler to a Tank in the airing cupboard, however the tank also has an immersion heater which I'm about to replace the flex to, however I've never used the immersion I've always run on gas. I want to keep the capability of using the immersion heater if the gas boiler fails for whatever reason but want to @Isolate@ the power supply to the immersion heater. (As I will not always be the one in the house).
Is it OK just to remove the Live wire from the Immersion heater MCB (20A) in the CU ?................if so where do I put this @bare@ wire...what is the protocol for doing this ?........do I have to sleeve it up...or secure it anywhere ?.........I don't for obvious reasons want to cut it off because I won't then be able to connect to MCB in the event it is required.
Thanks,
Paul
sounds like an unusual set up. anyway to answer your question, dont play around with the mains board (CU) either completely disconnect it or dont.
what do you mean by isolate? the flex that goes into the heater should come from a switched fused spur. If this is switched off no power will travel through it, yet it'll be ready to be switched on wenever it is required.
If its not on a switched fuse spur - put it on one.
To wire the new flex (why are u doing this?) just turn the breaker off at the CU
what the hell was wrong with your original thread???? anotehr one who doesn't appreciate we aren't mind readers and might not realise we have two threads on the same subject by the same poster.
Wasn't the same subject.............after reading the post at the start of this thread I then thought about why do I need "both" methods of heating & would like to go down the Gas route & immersion only as back up.
