Having posted the below message and received answers that there might be a bad connection, I checked the wiring but couldn't see anything wrong. Nonetheless, I removed the thermostat and wired back in.
Unfortunately, after just half an hour of the heating being on, the water is still overheating. It appears the brand new thermostat is not cutting out the heat. Given that this is the second thermostat with the same problem, do you think that there is an issue elsewhere with the immersion? Maybe the element is faulty?
=============== original message =================
I bought a property recently with an immersion heater. The water was scolding. I tried to vary the thermostatic setting, but the temperature was always too hot to touch.
I visited the local plumbing shop who recommended that I change the thermostat. After changing the device, the temperature was still too high (factory setting was 65). I turned down the thermostat and immediately the temperature went down. However, this time is was just a tad too cool for my liking. So I turned up the thermostat a fraction. I went out for a couple of hours and when I got back there was the smell of burning. I sourced it to the immersion which I switched off. I took the immersion cap off and saw the inside was black and so were the wires although they have not burnt out.
