Immersion heater cable
31 Mar 2006
Yorkshire
Can anyone tell me what gauge of cable and flex is normally used for immersion heaters?
i.e. CU to switch and switch to heater?
2.5mm T/E from the CU to the FCU but no longer than 30m.
From the FCU to the heater I have read somehwre but can't find it that heat resistant cable is necessary but I don't believe it is in the Regs so may have just been a recommendation.
If that is the case then 13a T/E Flex will do the trick.
Unless someone else knows different.
Assuming there is a 13amp fuse in the FCU, and the element is 3kW power rating, 1.5.sq.mm flex will do fine between FCU and element.
