I have just taken on a flat which has two meters, one for off peak supply. (This is a new concept for me!). The hot tank is controlled through a Newlec Electronic 7 control which lights up to show off peak but does not heat the water. If I press the boost button nothing happens all the while the off peak light is on. Once it goes out my timed or manual boost works ok.
Do you think the timer is at fault, and how do I set the off peak times anyway? Your assistance will be much appreciated.
