I was called out today to look at a factory with no hot water. It was a large cylinder tank with three immersion elements, top middle and bottom.
Top, stat OK, element was I think 2.00 ohms but i can't remember for sure, no short to earth. Can hear faint bubbling when on
Middle, stat OK, element had dead short to earth.
Bottom, stat badly overheated, no short to earth, shorted between both legs of element but no continuity on element, swapped out the stat for another and can hear faint buzzing from tank when switched on.
All were switched on when I arrived, OK so im sure the bottom two are burst but should the top one not still be working? Im guessing they have all failed one at a time and they have only noticed there was a problem when the last one failed.
