After the immersion heater failed, I tested that a current could pass through the elements with the heater in situ, and it could not. I isolated the water flow, drain from the bottom of the hot water cylinder and extracted the element. It was visibly split. I have replaced the element with thermostat and it worked wonderfully for 5 days. The second one now fails to heat the water.
Before I embark on the same process, is there any lessons I could learn from i.e. the second one failing must be statistically unlikely?
