Immersion Heater faulty - testing..?
5 Jan 2010
London
I have an immersion heater, and use it to heat my hot water in the cylinder. It has stoppe dheating the water up, so I tested the thermostat for co ntinuity with the stat turned up and there was no BEEP. So I now want to test the immersion heater itself, but cannot remember the Ohms I should be looking for, it is a 3KW heater, top entry. The fuse to the heater is good by the way. Also, when replacing (if the heater is at fault after testing) - is PTFE tape good to use round the heater threads or just the fibre washer and any compound? I don't want a leak if I can helpt it.
Thanks for your help.
Element resistance should be approx 19.2ohms. (assuming 3kW element)
Just use the fibre washer
ok, thanks. So more than that and faulty, or less than that and faulty??
hawk white any god around the fibre washer ?
No jointing compound :eek: It`ll make it hard to get out next time . Ptfe is ok . and what I always used ;)
