Immersion Heater - No Hot water
4 Jun 2009
Lancashire
Hi everyone
My mate has an old hot water tank, heated up by an immersion. He's getting no hot water today. I have checked the stat hasn't tripped, and tested for continuity and the meter bleeped. I also tested the resistance of the element itself and the reading was 19.6 Ohms.
The neon indicator on the switch that feeds the immersion is also lit up.
What could be the cause, as I can't think of anything else? :cry:
Thanks for reading my post.
Have you checked that actual thermostat?
This could have failed.
I did a continuity test on the stat and it bleeped, so it was calling for heat. (circuit made)..
Thank you for helping btw,
