The story is:
Our immersion heater was spewing water out of the overflow, the plumber came and fixed it by putting in a new one way valve (I think something to do with ensuring that as there isn't a lot of pressure hot water would still come out when we needed it) and a shower mixer in the bathroom as you could hear the cold water running back through the pump (we have a pump as there would be no water pressure without it).
This solved the problem of the water spewing out as it was stopping the cold water pushing its way back into the tank.
Only problem is now the pump runs/turns over every 10seconds or so even though no taps are open. So we have it turned off unless we need lots of hot water. Not very convenient.
Any ideas what the problem is?
thanks
thanks
