We have a 35 yr old hot water tank. I want to replace the immersion element but can't get the old one out. I have a box spanner. I put lots of WD40 around the top first, then tried undoing it. No movement at all. I tried tapping it around with a hammer, and still nothing. Then tried hitting it a bit harder. I believe the top of the tank has started to deform as the insulation feels hollow on one side of the immersion, and the top of the immersion is leaning more than it was. Luckily no leaks when I turned the water back on.
So, how do I get the immersion element out without replacing the tank? Or will I have to replace the tank to replace the element?
Ant
Ant
