Immersion heater test
11 Sep 2007
Hi guys,
Can anyone give me detailed instructions as to how to use a multimeter to test Immersion heater and thermostat?
What settings do I use on meter etc?
Cheers
with power fully isolated
set meter to resistance.
check resistance thru element, a figure of approx 13 ohm and infinity to earth would indicate a healthy element.
240/13 = 18.46 Amps.
What kind of elements are you used to? :confused:
Well the resistance is temperature dependent, so Softus' sum isn't accurate :cool: , but they're normally about 20 Ohms.
sorry im giving the figure for current my faulty maths. :oops: :oops:
should read V2/watts (230v x 230v)/3000w
which = 17.63333 ohm, which is very close to 20 ohm
nominal voltage being 230v element being 3kw
I believe that most elements are rated 3kW at 240V.
You're quite right of course.
Except the ones that I measure, that are closer to 19 Ohms. But we're not trying to be accurate, are we? ;)
That would give a power output of over 4 kW !!! And 18 amps through the 13 amp fuse!
I suggest that about 18 ohms element resistance would be more appropriate for a 3 kW element!
Tony
Tony
yes and and as you know well as you can read i apologised for giving that wrong figure using a wrong calculation,i confused current for resistance.
primarily because its a formular i would never use.
why?
because i would never do it that way.
but when some asks how to do it with a multimeter, i have to turn and say that no one should ever use a multi meter to perform these forms of testing.
as a live test.
a multimeter is not a recognised test instrument and should not be used when live testing.
so all i can do suggest dead testing techniques
Oh, well spotted.
Have another vat of wine, Agile. :rolleyes:
The difference is that I know from previous regular measurements what results to expect when I test elements.
If I didn't then I could still use Ohm's law to calculate it.
I admit I replied without reading all the other replies others had given!
Tony
whatdo iknow said:
look its a 3kw element and a 230v supply ok?
I very much doubt that. Have you measured your supply voltage recently?
