Just want to make sure of something is possible please?
The Immersion Heater/Thermostat wiring is: Live goes through T (thermostat) and this T (thermostat) makes or breaks the circuit, depending if calling for heat or not (when switched on)!
Then from the T (thermostat) the circuit is completed by going to the N (neutral). So.. basically if the thermostat if satisfied (at temperature) the T (thermostat) breaks (opens) the circuit and the N (neutral has no power to it ...?? is this right?
If the Thermostat is faulty then when switched on and turned up (calling) there will be no voltage between L & T terminals?
And if the immersion heater itself is faulty (and not the thermostat) there will be no voltage between L & N terminals .... is this correct?
Thanks for clearing this up and sorry for any confusion!
