Evening all.
I have just had half of my house rewired due to refurbishing and moving the boiler and hot water tank. The old system had the boiler and immersion running off a separate 2.5mm cable from the consumer unit.
Now that the work has been finished the plumber has installed the boiler and hot water tank, however, has not wired up the immersion on the tank. When I asked him why, he said it needed its own supply from the consumer unit. Is this correct?
The boiler has its own 2,5mm supply. So is it possible for him to come off that with a 13Amp Fused spur to connect the immersion? Or is he correct and we do need a another seperate 2.5mm line running?
Andy
Andy
