- Joined
- 22 Jan 2007
- Messages
- 8,377
- Reaction score
- 4,235
- Country
I'm doing first fixing for a cylinder/boiler installation.
The Hot Water Cylinder will have a 3kw immersion heater fitted to it as a backup device should boiler ever pack in.
The cylinder will be in the room next to the CU.
Normally In past properties I've worked in, the cylinders been upstairs, with a standard looking Isolation switch, and a fused spur downstairs.
So Im looking at laying 4mm T+E between CU and a Double pole Isolator (non fused) 4mm flex from isolator to Immersion heater, and ordering a 16A RCBO for the CU.
Total length of cable will be less than 4meters and will be clipped direct, but if the immersion is used it could be drawing 3kw for hours and god knows what insulation etc will go down in future.
I was really wanting only to ask if it would be acceptable to fit with just a DP isolator or whether it would need to be a fused spur ? hear arguments saying one over the other now so got a little unsure what to get.
TAI
TAI
