immersion heaters :-Safe removal of.Another bright idea!
17 Feb 2005
If, when trying to remove electric immersion heater from cylinder the locking nut appears stubbon, and you fear that you might crumple the tank, try cutting through the gasket that is between the flange of the heater and the top of the tank, with a hacksaw . This breaks the bond as the gasket will have "cooked" over the years and gone hard and brittle .
I'll give that a try clever-clogs and let u know how I get on, I've got a cylinder outside I need to sort before it goes to the scrappy.
if its that old, it'll have a low recovery anyway and it'll have a good layer of scale. Just replace with new vented cyl and approved stat. :idea:
