Immersion Help!
18 Apr 2012
Any help will be much appreciated. Water heater was heating the wter absolutely boiling so I replaced both rod stats. Now the top stat (the boost) is working fine, when power goes to it it starts heating up, making a noise similar to a kettle boiling but not as loud but when the off peak comes on it's not very warm, doesn't sound like it's heating and make more of a quiet whistling noise as if it's struggling to heat?! Is there any chance it could be more of a plumbing problem now?!
Get an engineer to do a load test on the element using a clamp meter- the element should be pulling around 11-12amps if not it is likely that the element is faulty this can be confirmed after checking the new thermostat for continuity and ensuring 230vac between L & N and L & E there should be <1vac between N & E if these tests are OK it is likely that the element needs replacing :wink:
Thanks for your help. It's very strange as I'm getting continuity between the terminals in the immersion around about 20 ohms so I'd imagine it's ok but maybe not!
