A mate called me to say that he has no hot water due to the immersion heater not working. He also tells me that there is sings of melting in the consumer unit. Am I right in saying that he needs a new thermostat fitted. Advice most appreciated.
kai said:The Earthing to the immersion may be suspect, as the mcb did not trip out in such a serious fault.
A run of 10.0.sq.mm. (TEN-mm) cable from the Immersion Cylinder to the Mains earthing terminal can be a good idea...
ban-all-sheds said:all ( ) that would happen would be the hot water tank boiling.
What are signs of overheating but not quite melting?Gee said:The CU at the immersion mcb area does show signs of overheating but not quite melting.
Aren't they supposed to be vented? Mine was, until I went combi.securespark said:On Friday, I visited a house where the stat failed on an imm htr, and the tank failed - boiling hot water everywhere - enough to melt candles in the next room into nothing!
No it won't. If the circuit has been properly designed, and the earth-fault loop value is within what it should be, then there is no need to stick a 10mm² parallel earth path in there. If your R1 + R2 value is too high then you need to look at the whole thing, not just bung in a thick earth cable.kai said:That is why you should apply regulation 607, and earth the cylinder too properly, or you may receive a fatal shock if this happend in your home.
10.0.sq.mm. earth is NOT OTT in this instance, it reduces the touch voltage to a lower level, in the event the fuse fails to blow.
Hard to miss....You might note that I have a tenby clamp on ALL pipes leading to and from the cylinder, linked with 10.0.sq.mm. earth cable back to the fuse box.
