I have just upgraded my consumer unit to a new 12 way MCB slit load. On commissioning everything is working fine with the exception of the immersion heater.
Initial examination of immersion heater showed that the neutral wire sleeve had burned about 25mm along its length and that the thermostat showed signs of overheating. I have replaced immersion heater for a new one and I still the RCD trips.
The scenario:-
The line is from 16A MCB on non RCD side of unit.
From MCB to timer to 20A switch to immersion.
When powered up, immersion through timer works fine with TV or hover on. However, when I switch on the kettle or cooker independently the RCD trips.
I have bypassed the line under the floor and have gone from timer to 20A switch with 2.5 T&E which works until I switch either the kettle or the cooker on. The RCD trips.
I have bypassed timer and have gone from MCB to 20A switch with 2.5 T&E which works until I switch either the kettle or the cooker on. The RCD trips.
Both the cooker and the kettle on together or independently no RCD trip. (Immersion disconnected).
The Cooker on 40A MCB.
The kettle is on 32A MCB kitchen ring.
Immersion is on 16A MCB .
My brain is frying on this one. Can someone please help.
The scenario:-
