My aunt has a problem with her immersion tripping the rcd on her consumer unit. The problem has only recently started occurring and occurs even when all other mcb's except the immersion are switched off. I have checked the wiring to ensure all is correct and tight at both the cu and the immersion and all seems to be in order. The rcd trips after about 15secs, and from memory the rating of the rcd was appropriate, but as i day the problem has only recently started occuring. When the immersion mcb is switched off and everything else on the rcd doesn't trip.
Though the current wiring to the immersion looks up to date, some remnants of the old wiring remain at the immersion end (unconnected now) but would possibly indicate that the immersion element is fairly old.
Could a fault in the immersion element be causing the trip? If so how and would a replacement element be the easiest solution.
My aunt is 96 and lives on her own so I don't want her to be 'preyed' on by anybody unscrupulous!
Any ideas greatfully received......
