hi all,
i have a hot water cylinder with twin immersion (side entry) both 11" bottom for off peak, top for boost,and i would like to add horstmann timer,as the top immersion is not in use how difficult is it to add a timer to the circuit,also what size flex should be used from 20amp double pole switch to thermostats 1.5mm 0r 2.5mm,any advice would be appreciated
thanks
thanks
