Impossible access for readymix concrete what options?
14 Jan 2010
Bristol
I need to concrete the sub floor to stop rats getting in, we've tried poison, galvanised wire mesh and now the only option left is to concrete the sub floor area.
The only problem is access, I don't think I can get ready mix to do the job because access is from the front of the house, via a 6 metre hallway with a 90 degree bend at the end to get access to the subfloor. To add to the problem I can't get a wheelbarrow around the 90 degree bend without having to tip it upright.
So what's the most labour efficient way of getting the concrete in? Can I dry mix the concrete in situ then spray it with water like postcrete?
Help please
concrete pump how much concrete do you need?
why such why not cal pest control guy to get rid of them???/
try select mix i think there called they have on site batching so you only pay for what is mixed and used and they have a pump on the lorry
Don't you think we've tried that!!!?
Thanks for the company name though
concrete pump
Don't discount knocking a hole in the lower front wall of the building, or pumping with a crane over the building and bringing the hose in from the rear
