Hi
I had a combi installed about three months ago, into a house with a very old conventional style boiler (i.e. header/expansion tank etc). We replaced it because it wasn't working and a combi was more effective.
Now when the plumber did the installation he has capped off the hot and cold water feeds in the loft, which is 22mm pipework - I know this as I am starting a conversion! We have a downstairs bathroom, and kitchen etc, so there is no need for water upstairs. Can I simply cap these pipes off downstairs to improve my hot water heat up time? Downstairs is all 15mm pipework.
I am thinking about adding a washroom upstairs. If I did this, could non-return valves be used where the pipes run upwards to the first floor, to ensure the downstairs hot water heat-up time remains reasonably quick?
Thanks in advance for the help.
