Hello everyone. This is my first post on the forum after much lurking.
I have very low hot water pressure in my upstairs basin mixer tap. Being in a maisonette there is hardly any head height from the tank (about 0.8 metres). However there is decent enough flow from the bath tap (separate hot & cold taps) which only slightly lower (a further 0.4 metres). This has led me to conclude that whoever fitted the tap probably didn't choose one suitable for a low pressure system.
The minimum pressure tap I have been able to find is 0.1 bar. It has M10 connections and the flexi tails included - but they look like they will still be restricting flow somewhat as the aperture of the tails is pretty small especially at the compression nut end. So I have been considering using some copper tap tails instead. I have also been searching for a monobloc mixer tap which has larger M12 connections for the best chance of maximising flow, however, I've not been able to find any... in fact you practically never ever see thread size included in specs!!
If anyone's had a similar problem perhaps you could advise? Am I on the right lines... or getting a bit carried away? I don't want to fit the new tap only to find the flow is still poor. I'd also like to exhaust all other options before fitting a pump on the whole hot water system.
Thanks!
Thanks!
