Hello to all
We have a pretty standard family home, with a pretty standard gravity-fed system. Cold tank in the loft. HW tank in the airing cupboard. The system works, and works ok. It is a positive head system.
We have two bathrooms, and the HW supply to the taps/gravity shower in both is ok, but not amazing. It’s certainly usable, and we’ve used it quite happily for the past 20 or so years. The HW pressure in the downstairs kitchen is weaker. As far as I can tell, the cold water supply to the downstairs sinks is mains, and the cold supply to the upstairs sinks and showers/baths is gravity from the loft-tank.
We’re going to completely refurb a bathroom shortly, add in Hive and some other jobs, so now seems a good time to improve the overall system if I can. I am absolutely not interested in conversion to an unvented, pressurised system, no matter what the potential benefits or costs. I simply want to increase HW pressure to the upstairs showers (which are in baths – not standalone showers) and kitchen tap if possible and reasonably practical. The pressure in the kitchen tap is certainly usable, but I’d like to increase it for two reasons;
1 – So that it is closer to the cold pressure
2 – So that we can use high pressure designated taps in the kitchen/utility rooms if we wanted to – at the moment, we’re restricted to low pressure taps.
Therefore, looking at several potential products to solve the problem, but would very much appreciate any expertise? I've also been reading this thread here:
https://www.diynot.com/diy/threads/...t-water-pressure-to-taps.438538/#post-3424176
It appears that I should be considering:
Many thanks
- 46497 Stuart Turner Monsoon Standard 2.0 Bar Single Pump (Positive head)
- Grundfos UPA 15-90N (160) Domestic Home Booster 240V
- ShowerPowerBooster
Many thanks
