Hi
we have just purchased a 1980's house with large front and rear dormers, and i'm hoping for some advice from the experts please.
were having quotes on getting the dormers done in epdm with new plastic cladding at the minute , but the quotes seem to vary wildly, with detail on whats being done a bit vague.
i have asked for improved insulation, but as the dormers are being done should i be specifying a certain standard to them? and what would be a good setup for improved insulation?
i've read up on cold/warm roofs. i take it the dormers will probably be cold roofs at the min? should i be requesting/should they be advising to convert to a warm roof?
where i can access the void in the eves i can see the rest of the roof is currently insulated using foam/polystyrene sheets/tiles. could this be further insulated by inserting rockwool or similar? or am i asking for condensation or other problems?
where the rest of the roof slopes at the ends inside the dormer bedrooms, and the flat portion of ceiling overhead between the two large purlins/beams that run the length of the top floor, could kingspan plasterboard be installed from underneath?
obviously this would decrease room space, but as the rooms are pretty big, if it is effective at improving insulation i could live with any losses.
thanks in advance, any other advice or recommendations welcome and appreciated
