- Joined
- 5 Nov 2010
- Messages
- 389
- Reaction score
- 3
- Country
Wasn't sure if this thread should've been posted in the 'Garden' forum but because it's about water pressure, thought this forum was more appropriate.
I have bought two garden sprinklers from Screwfix. When one is connected, it works fine but when both are, they don't work properly. This must be because of not enough pressure is being created.
I thought my water pressure was fine. It's certainly fine indoors. Apparently, Screwfix say you need 2.0 bar to operate the sprinkler but don't know for two.
What I'm wondering, are there certain things I can replace to increase the pressure?
For example, would it help if I replaced the hose connectors that have the built in water stop valves with ones that don't? Increasing the hose size? Replacing the garden tap with a special one? Using a more rigid pipe between the sprinklers?
Thanks very much.
Thanks very much.
