Okay, i used to have a boiler, make hermann ( no ones heard of it ) :S
so few days ago got it replaced from this bogus company ( lets not get into that, storys too long). Got a Vaillant EcoTec Pro 28 as a replacement. so the next day i was hoping everything to be fine but realise in the morning the boilers water pressures gone down to 0 and the red light was on.
I let the fresh water in and the system repressureised. Before the boiler installation the plumbers did a chemical flush so i thought the water pressure going down must be some sort of blockage is being cleared up. Now been 2 days i have refilled the system 4 times now.
I am really worried as somewhere in the net i read that refiling your system alot is really bad and can cause serious problems ?
Anyways its obvious that theres a leak somewhere but before the installation of this boiler we didnt have that problem but i am thinking this could have occured due to the flushing? also today i am keeping an eye on it and i realise that the pressure suddenly drops everytime the central heating is on? is that normal or is there a definate leak somewhere ?
I gave all my money to this bogus company and now im in more mess and dont have any money left. My flooring is laminated downstairs so if i have to get engineers to lift up the floorboards and find a leak ill be in serious debt : /
I am hoping is the boilers fault so the company will fix it as it was just installed few days ago or if there is a leak i hope putting in some sealer will block the leak ?
how big does the problem sound ?
thanks in advance
Edit: Plumber is saying this small leak also could be the problem so to dig in without rectifying it is stupid but we cannot find a replacement valve for this. The water inlet and outlet to the radiatior thts leaking is from the SAME PIPE!? the other end where the water return is capped so looks like one is for feed and the other for return. Any ideas ?
thanks in advance
