The old pipe work has developed a leak in the bathroom... This has caused damage to the downstairs flat.
Basically there is a right angled joint, about 40mm length of copper tube, followed by a weeping slip coupling and a long run, this is at the back of the bath.....
The only thing I can think of, is to cut out the joint and fit a long 22mm compression slip coupling, but I cant find anywhere that does them except in the states! The local plumbing store only has the normal (non slip) compressino joiners.
Any ideas or links where I can get one?
Thanks in advance.
Thanks in advance.
