Hello all
1st post...
I have recently moved in to a house with electric underfloor heating. House was built in 1985 but UFH installed in 2013 from what I can gather.
I noticed that the FCU faceplate for the UFH was cracked and was also getting warmer than I would like when in use. Therefore, I bought a MK FCU to swap with the existing (unbranded) FCU. Fairly simple swap of nice new brown and blue T&E. However, upon inspection, the neutral from the load side was wired into the supply side and vice versa. Line was wired correctly... I swapped it over and wired it correctly but I'm intrigued why the incorrect wiring still worked and what the possible implications could have been? As you can tell I'm no electrician.
Thanks for any insight!
Dan
1st post...
Dan
