Increasing rebate depth for double glazing.
5 Dec 2004
I have a large, 1.8 x 1.2 metres arched hardwood window frame with proper leaded lights which are leaking and beyond economical repair.
I wish to reglaze the window frame which is in sound condition using double glazed units.
Unfortunately the rebates are not deep enough to accept double glazing and
I propose to remove the frame and increase the depth of the rebates with a router.
My question is has anybody on this forum done this and if so can you let me know how it worked out and what if any problems did you experience
I had my windows done about 19 years ago. The guys who did it never removed any frames.
All done in situ.
All done in situ.
I did consider that, but the window has a series of radial astragal glazing bars from the inner arch and it would be difficult to say the least to router those in situ.
a point to note
you are removing perhaps 15-25% off the glazing bars strength then increasing the overall load by 100%
so unless they are good and chunky you are relying on the sealed units for supporting themselves and other units away from the main outer frame
a point to note
Fair point but the radial glazing bars are the same dimension as the stiles mullions and transoms. Ex 75x55
I probably misled you when I referred to astragal bars.
The attached pic will describe it better.
View media item 66115
7 panels will work fine have you tried asking the question off costs and size off the d/g units
you do realize you will have to pay building contol to pass them or have them installed by a fensa fitter
are you 100% sure they are rebates. sometimes it can be beadings both sides.
it's obviously a lot easier if that's the case.
worth stripping the paint on one of them and having a check.
