indent fan oven
21 Feb 2014
down south
i have as above , while cooking dinner other night, the oven caused main board to trip , i reset it and carried on using oven,thought it was surge . but next night the oven doesn't heat up at all. light , grill and fan still working, just blowing cold air. is this an easy fix ?? maybe heating element, just a guess.
does anyone know what is wrong ??
thanks
paul
sorry the oven is a delonghi. also if it is element, i can't see it, i suppose it might be behind back panel on the inside behind the fan, I'm just guessing hoping someone could tell me otherwise.
all the best
paul
Assuming it is the heating element, then check partmaster to see if you can get it, then decide if it's worth doing. It's not difficult to strip out an electric over, and there's no PCB in it, so as long as nothing else has gone (and you feel confident and are capable) then it should be straightforward to do.
Take the element out, cover up the loose connections, and see if the breaker resets itself.
sound mate , to be honest , after looking at it , its easier than i thought , i have no continuity on element so i have the answer, i have not rang anywhere yet , just need to find out what model number it is to get part , no paperwork & serial numbers rubbed off , will ring monday if serial number required . when buying on net you can't physically match part. thanks for your time doggit
