indeset widl126 fault lights flashing not working......help
23 Nov 2012
Manchester
hi.... I'm new to this so please bare with me if I as a lot if questions. I have indeset widl126 washer/dryer. This morning I set it to do a cold delicate wash and it didn't finish its cycle and also the fabric softner was still in tray wen I checked. The lock button light is flashing red and the delay timer and the easy iron lights are flashing green.....any ideas? I can't afford a new washer! Due baby in 2 weeks pls help xx thank you
Communication fault , unplug for 2 mins. Also make sure connections are on the pcb tight.
The curcuit board. Found at back bottom right.
OK thank u .....my partner is an electrician and bk tomo morning so I will get him to check....thanku very much!!! X if any problems u will be hearing from me again. Thanks again for help xx
