As above the dishwasher goes through part of the programme then stops, manually advancing the dial it then goes to the next part but just stops again, manually advance dial round & ping it trips the electrics.
I have tried to find out if there is anything blown inside but there is nothig obvious, the pump/motor etc seem to be okay.
I have reset the float switch as discussed on here amongst other things!
I have found a source for a timer, does this sound likely to be the cause?
It's £45 so if it isn't that then............
