Well after just splashing out on a new fridge freezer, our washing machine died last week and now today after Christmas Dinner our Dishwasher seems to have died as well
It's an Indesit DIF04 and it'll be 3 years old in January.
We came to use it after xmas dinner and it wouldn't start the program light would select but when you closed the door nothing happened. We did think it used to make a beep when you changed programs but we couldn't be 100% sure. (it didn't beep now)
We also didn't seem to be able to switch it off.
I switched it off at the mains and back on again and it didn't come back on at all. Then suddenly after a few minutes it came on, again the power light was on and it wouldn't turn off and it wouldn't start when you shut the door.
I came to look on the internet and after another few minutes it started beeping when I went back the power light was flashing and so was the soak light and the eco light.
I looked it up in the manual but these lights aren't mentioned. There are other fault lights but not those two.
I've done all the basic checks - I've cleaned all the filters, I've taken off the supply hose and made sure it is working, I checked the supply filter, I check the drain hose for blockages. I popped the bottom off and removed the drainage pump and the impellor rotates freely.
Anyone know what those lights mean? Anyone have any other thoughts on how to fix it?
