indesit dif04 fault light codes
2 Feb 2014
Lancashire
I have a indesit dif04 belongs to my daughter and is now in my garage connected up while I try and figure what's wrong with it.
It is the fully integrated version with the controls on the top panel inside.
You can power it up and select a programme , its starts the pump for a few seconds then fills with water , stops and the power light and the three programme lights to the left all flashes, it starts the pump and empties the machine , it will stay in this mode with the pump running until you switch it off.
Any bright ideas?
Faulty turbine. Found on the left hand side of the dishwasher.
Also check the pressure switch, tube connected to it and also at the start of the tube is a chamber that effectively increases the air pressure to the pressure switch.
This chamber often fills with crud and produces exactly this symptom.
Removed turbine , inside all tubing and plastic containers look clean , turbine shows dead short , looks like a magnetic reed switch which presumably counts pulses as turbine goes round , can get one for £17 will let you know what happens
Cheers Stuart
Ok renewed turbine now I get same result as starts filling then pumps out but have 1st and third light flashing instead of all three ???????
Have changed turbine but still get same fault but now I have 1st and third lights flashing ????????????
