We have an Indesit DIF04 integrated dishwasher.
We have had it for about 7 years now, used daily. In that time we had fault where the wires split in the door when it was about 5 years old. I was able to repair these and it has continued fine. We then had the heater element die so I replaced the main circulation pump which houses this. It then carried on for another couple of years.
Earlier this week it was refusing to start, lights 1 and 3 were flashing, which according to the manual is blocked filters. When I say refusing to start, it does actually start - it does the normal single beep to acknowledge it is starting, you can then hear the drain pump going and a gurgle in the sink. Then it stops (you normally hear water going in at this point).
I removed the three parts to the filter and gave them a good clean but it made no difference. Through sheer determination we made it work by just continuously trying until on one go it decided to work. However the next time it failed again!
I turned it up and removed most of the parts from underneath and checked them - no blockages. I gave everything a clean and reassembled. The drain pump visually looked in good order and didn't have anything wrapped around it etc.
I've put it all back together and now when I try and run it, it all starts off fine but it fails much further in. It doesn't seem to ever get to the three beeps and instead when I come to it, I find it has the same two lights flashing (1 and 3). The dishes all seem to be spotless at this point so I'm guessing it must be near the end of the cycle.
So I can't figure out what it is.
My guess would be the drain pump, but it seems to be pumping out the water, if I tip a glass of water into the filter it will remove it all during the first run of the drain pump.
I have also taken the door off to check for any more broken wires but all looks good there.
