Dear all.
I have a problem with my Indesit DPG15 dishwasher and the symptoms are as follows.
The machine starts ok, fills through the opening in the left hand side of the machine, you hear a click (like a micro switch proving) and then nothing.
The program continues as though everything is ok and the machine empties as it should but the spray arms do not clean the dishes.
I'm guessing (correct me if I'm wrong) that there must be a pump fault somewhere for the water to not be reaching the spray arms.
One last point, you do get a small amount of warm/hot water through the inlet in the bottom if you take the spray arm off.
I have had a quick look online to try to find a service book for the appliance but to no avail.
Thanks in advance.
Stuart.
Thanks in advance.
Stuart.
