My diswasher is blowing fuses (well its now on an RCD to try and keep diagnosis costs down).
When I set to the reset programme its fine.
When I set to say programme 3 (25 mins 45 degC) it runs, fills with water then blows the fuse/tripps RCD.
Would I be correct in presuming the heater has fubared?
If so can I open up the underside, disconnect the heater then run it to proove that the heater is at fault or will the dishwasher shutdown as the heater is unplugged?
