Indesit IDL40 leaking problem and blows RCD.
23 Aug 2005
Cheshire
I have an Indesit IDL40 dishwasher that has been really good.
For some reason water leaks from the bottom of the door and the power trips.
I did manage to soak all the water up and get it running but just does the same thing.
Could it be blocked some how?
Check the ring nut at the Back of the tub. Are the spray arms split. Do u use 3 in1 and rinse aid.
Where is the ring nut? Nothing split and use rinse aid and salt and tablet.
It is almost like sonthing is blocked or somthin?
Starts filling then comes out the sides of the doors then power trips.
The bottom just stays full of water.
Check the pressure switch on the right hand side poss blocked, blow down it see if it clicks.
Not able to blow put if I suck water comes out?
Where is the pressure switch?
At the end of the tube that your sucking. If you cant blow down it it's blocked.
Any suggestions how I unblock the tube?
If I suck water does come out?
I thought you wouldn't be able to blow down the tube?
