Any trade in the UK here? I wonder how I can get trained in washing machine repair?
Anyway, This is about 2 and half years old, cost £190 when new.
Indesit IWC71452eco UK model.
It has been lightly used since new never overloaded.
It worked fine up to Monday then yesterday Thursday it was attempted to be used again.
It was put on 60deg was and apparantly started to fill but not for long, after 30 mins it was found to have done nothing and was just not active. She turned it off at the wall, and turned it back on - nothing.
I first looked at it this morning, this is what it is doing.
Turn on at the wall get the normal beep beep beep. If door is closed, door red light is on, can't open door (we believe this to be abnormal) , Start button flashing green, when pressed, the start light turns solid green and the wash selctor green light lights up on the appropriate section - according to the wash selector dial. but the machine stays silent and does not do anything for 10-15mins when all the lights start flashing and the drain pump starts to action to empty any water in the machine when it is empty it stops the pump and remains flashing and silent with the red door lock on. I usually press the on/off button here and the flashing lights go out just the red door light remains on and never goes off. Then I turn it off at the wall and after 3 mins the door lock releases.
I tried filling it manually with water just after pressing the start button in case the cold water valve was stuck, but nothing happened same thing, until the flashing and the pump empties the machine.
Thanks for looking.
Thanks for looking.
