Hi had a burnt out interlock on above model, bad on 2 brown wires so joined, lock light on but still nothing I take it new or repair module required anyone please?
Didn't get any help on here unfortunately but I did sort it, because of rubbish Indesit plugs on especially door interlocks, fried the plug wire and lock as mentioned above, but just for good measure they normally pop something on the main board / control model. Replaced both second hand cheaply luckily module came with the hole wiring loom, so that had the plug and wires on it! Sorted boom.
